curiousgeorge
#1 Posted : Wednesday, May 11, 2022 2:51:38 PM(UTC)
curiousgeorge
I am using VMIX and a Black Magic Pocket 4K.
I created a custom LUT and selected the option on the camera to APPLY LUT TO MONITOR and APPLY LUT TO HDMI.
Next, I load up VMIX software, check VMIX color settings to ensure NO color modifications are being made. Everything looks perfect, exactly as the LUT is supposed to look. EXCELLENT!
Then, I click on ATEM SOFTWARE CONTROL to fine tune audio levels, and as soon as it loads up, the entire color settings go hay wire in VMIX.
Then I check the color settings on the ATEM MINI SOFTWARE CONTROL and I ask myself: HOW DO I PREVENT ATEM MINI SOFTWARE FROM INTERCEPTING THE COLOR CONTROLS? I JUST WANT IT TO LOOK LIKE THE LUT APPLIED IN THE CAMERA? CAN'T IT JUST PASS THROUGH THE COLOR SETTINGS WITHOUT TRYING TO INTERVENE? HOW DO I DO THAT?
