MultiCorder 6 4K feeds in ProRes 422 or similar
Hello!
I'm in a situation where I need to record 6 4K camera isos coming in over SDI via a couple DeckLinks. The codec needs to be ProRes 422 or similar for archival purposes. Is vMix capable of anything like this?
We will have quite a capable machine with a threadriper 3xxx and a current quadro, likely an A4000, so we'll have some horsepower.
TIA for your help!
Joined: 3/7/2012(UTC) Posts: 2,690  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
@ EBCOMConnor
FFMPEG supports a ProRes option in the Codec dropdown menu of the MultiCorder. so worth a try. How your system responds to 6x 4K .mov ISO recordings (and whatever else you have going on) remains to be seen...
