Is it possible to output the source to another vMix? (Different networks)
Joined: 3/25/2022(UTC) Posts: 2  Location: Norway Thanks: 1 times
Hey everyone, I've seen some topics about this but they're all really old (4-6 years).
I work at a TV-station. We have one vMix computer in house that outputs directly to TV. I could use NDI, and have before, but this time the other vMix computer will not be on the same network. Is there any way to send a vMix output to another vMix? Or any other smart solutions?
I would really appreciate any help, Thank you!
If it is possible, there are several ways to do it, via srt, via rtmp through some server and through NDI bridge, I hope the information will be useful to you, there are several tutorials on how to connect or send signals outside the private network to another network. Cheers
Joined: 4/23/2017(UTC) Posts: 1,494  Location: Germany Thanks: 3 times Was thanked: 199 time(s) in 179 post(s)
Just today I used NDI bridge with another location over the pond. It was working perfectly. SRT is great as well.
Quickest and easiest way, in my opinion, is to use vMix call. You will get 1080P resolution and two way communication, if required. The latency would be very small, assuming you have a good internet connection.
Joined: 1/5/2022(UTC) Posts: 11  Location: east java Thanks: 2 times
I'm working at TV too.
I'm using vMix call to send the Output to remote PC.
