Tone13
#1 Posted : Monday, April 18, 2022 8:33:49 PM(UTC)
Tone13
Hi there,
I have been supplied an image sequence that I need to use in a GT Title. The sequence loop point is at 20 seconds (which is the end of the image sequence). Seems like the duration limit is 10 seconds becuase even if I type 20 in the duration field, it sets itself to 10. This means that the image sequence, despite playing corrently in the GT Title designer, plays back at double speed in vMix itself.
Any fix for this?
Nathan232
#2 Posted : Saturday, May 14, 2022 12:29:03 AM(UTC)
Nathan232
Not the best fix but you you can cut it in half and have it as a data source in/data source out which will give you the full 20 seconds. And then create a trigger to keep activating it as needed?
Just a thought
