cutter07
#1 Posted : Friday, April 15, 2022 12:54:27 AM(UTC)
cutter07
We need MAB Bus for recording and streaming. Only new inputs should not be assigned to AB.
Unfortunately the dropdown for the default bus only goes to B. Is there any way to achieve this?
#2 Posted : Friday, April 15, 2022 1:27:09 AM(UTC)
how about using shortcuts (AudioBusOn/Off) to set the inputs to the desires busses? use the hover as input to make quick change
cutter07
#3 Posted : Friday, April 15, 2022 4:40:12 AM(UTC)
cutter07
Hi Doogy, thanks, but what means "use the hover as input"?
#4 Posted : Friday, April 15, 2022 4:43:38 AM(UTC)
new to vMix ? ;-)
with shortcuts one can select to which input it applies , one of them is Hover. The means when one triggers the shortcut it will apply to the input the mouse in hovering over .
Whne selecting an input in the shortcut setup one will initially not see that choise but scroll upwards and the choise will appear in the list
cutter07
#5 Posted : Friday, April 15, 2022 5:22:59 AM(UTC)
cutter07
Even if you are registered in the forum since 2012 and belong to the oldtimers, it does not mean that you constantly configure vMix :-).
I just tried the hover event and it worked - good to know there is such a thing.
thanks 1 user thanked cutter07 for this useful post.
jpetrie on 4/21/2022(UTC)
