Is there a way to change the fade speed when applying an overlay? I would actually like it to be more like a cut where it appears instantly and then is removed instantly.
Originally Posted by: JohnnyBG  Is there a way to change the fade speed when applying an overlay? I would actually like it to be more like a cut where it appears instantly and then is removed instantly. Overlay settings: and/or set it to cut https://www.vmix.com/help24/index.htm?Overlay2.html
