Displaying onto multiple monitors
Joined: 4/6/2022(UTC) Posts: 3   Location: Tool, Texas Thanks: 1 times
I have been using vMix HD in my church's Zoom broadcasts. My system is setup with display 1 as the main screen which is extended to display 2 and that in turn is duplicated on display 3 which is shared on 2 85" monitors in our sanctuary. During the service, we display hymn lyrics full screen on the monitors and use the screen share function of Zoom to broadcast a PTZ camera image of the worship leader with the shared lyrics side-by-side. We are getting ready to live stream through SubSplash and I have not found a way to have the full-screen lyrics on the in-house monitors and stream a layered image of the worship leader and the lyrics to SubSplash. Everything I try in vMix so far doesn't get me the results I need. Any help here will be sorely appreciated.
Joined: 6/27/2021(UTC) Posts: 43   Thanks: 50 times Was thanked: 4 time(s) in 4 post(s)
If you have vMix 4K or Pro you have access to a second external output. You then would just send one input to the normal output and another input to Output 2. You can customize each input to show whatever you like that way.
 1 user thanked jpetrie for this useful post.
