Feature Requests
Support Teradek Stream Protocol
I have teradek cube encoder and Wirecast Pro. However Wirecast use much CPU resources.
Recently I knew the vMix. It has great performance. But I can't use teradek cube using LTE not local wifi.
vMix only use rtsp pull protocol for teradek cube. I need push protocol for outdoor network using teradek cube such as Teradek stream protocol of Wirecast. Because LTE smartphone or modem has no public IP in Korea.
Do you have plan to support Teradek protocol?
If vMix has this protocol, it will be best video mixing software!!!
Have a good day!
Joined: 2/18/2014(UTC) Posts: 1,846 Location: Stockholm
+1 Teradek Stream Reader Plug-ins are available for both Wirecast and TriCaster. Not sure if it's an open protocol, or if Martin have to convince Teradek to create a plugin. Ref. Teradek on Cube's streaming methods.
Joined: 12/2/2014(UTC) Posts: 2 Location: Moscow, Russia
Thanks: 1 times Was thanked: 5 time(s) in 5 post(s)
Feature Requests
