christianb
#1 Posted : Sunday, April 3, 2022 5:17:00 AM(UTC)
christianb
Netherlands
hello, during our productions we go fullscreen 1 and 2 to the beamer, etc. The control is in a different room. Is it possible to make a preview of the fullscreen outputs so that you can see what is visible on the fullscreen output when operating? Maybe make the fullscreen 1 and 2 output also possible as NDI output?
christianb
#2 Posted : Thursday, April 14, 2022 5:41:04 AM(UTC)
christianb
Netherlands
have other people run into this problem and how do you solve it?
nikosman88
#3 Posted : Friday, April 15, 2022 6:25:40 PM(UTC)
nikosman88
Greece
Was thanked: 98 time(s) in 94 post(s)
Hello. I have same situation. I solved it with the simple way via hdmi splitter and hdmi cable. An hdmi splitter to the output of my graphics card and then one hdmi cable to my screen and another one about 20m for the screens in the studio.There i put another one hdmi splitter and i give 2 outputs for the 2 screen in the studio
If i had a pc in the studio i would use ndi tools. Ndi capture tool for my fullscreen screen and then to the studio in the other pc i would use ndi monitor and with cable to screen
jpetrie
#4 Posted : Friday, April 22, 2022 8:21:40 AM(UTC)
jpetrie
You could try vMix's Desktop Capture software – just know that I don't think you can place anything over it or else it will also be sent out on the NDI feed – https://www.vmix.com/sof...ture,-Click%20below%20to
