o.frank
#1 Posted : Thursday, March 31, 2022 12:03:08 AM(UTC)
o.frank
Views messages in topic : 2
Does Vmix 25 automatically use RUDP to send and Receive NDI streams? There is the NDI Settings that allow you to enable "send" and "receive UDP".
My question is now - does this mean it will use RUDP with NDI5? Is there a way to check if vmix is sending and or receiving RUDP?
Kind regards
Oliver
#2 Posted : Thursday, March 31, 2022 2:39:30 PM(UTC)
RUDP is the default in NDI 5, no settings need to be changed to enable it.
The UDP settings you mentioned are for older NDI releases only and have no effect on NDI 5.
eduardocfs on 4/1/2022(UTC)
