Hi all,
I discovered vMix today and considering trial version, but I won't be able to test it in next few days, so I would like to ask you if I am able to output processed vMix screen+audio to Avermedia Live Gamer 4K? I know that I Can input from AverMedia, but not sure, if I can send processed vMix signal to capture card..
My vision is to use vMix while gaming, process video in vMix (add custom graphics) and stream it...but I want also output processed vMix signal to TV and another PC, so I can directly see the exact screen which is on stream in real time and also record this processed signal to another PC as a backup.
So basically I want something like this:
1. Input from gaming console via Avermedia Capture card to PC with vMix 2. process the signal in vMix (adding webcam, graphics) 3. then send this processed signal via another Avermedia to another PC + TV
Is this possible?
Thank you :)
Joined: 9/10/2015(UTC) Posts: 138  Thanks: 2 times Was thanked: 35 time(s) in 32 post(s)
According to AverMedia's the site HDMI out port on the Live Gamer 4K is a passthrough port, not a renderable output: https://www.avermedia.com/us/product-detail/GC573Quote:• Video Input:HDMI 2.0 • Video Output (Pass-Through):HDMI 2.0 • Audio Input:HDMI 2.0 • Audio Output (Pass-Through):HDMI 2.0
