Feature Requests
Higher count of live streaming targets
It is great that there are now more audio channels available and LAN streaming has been added to vMix 25. However, the amount of streaming targets is still limited to 3. Is there a technical or licensing reason for this? I would like to send more streams in parallel. I.e.
- LAN streaming to another room in the venue place plus multiple web live streams - several streams with live interpretation at the venue place. Currently I am limited to 3 languages. - 3 languages, but in 2 stream qualities each.
Currently, I am sending the output via NDI to another PC which also has vMix installed. That is possible, but more complicated and error-prone.
Joined: 10/25/2012(UTC) Posts: 182 Location: Barbados
I would suggest taking a look at cloud distribution. 1 Stream out and distribute to as many endpoints as you want.
Maxi
Joined: 4/23/2017(UTC) Posts: 1,481  Location: Germany Thanks: 3 times Was thanked: 196 time(s) in 176 post(s)
It really depends on the streaming service you connect to. Some allow for multiple audio channels over SRT. Or Language #1 on left. Language #2 on right. You can also mix the video once in vmix and distribute with a matrix to kiloview encoders using some audio embedders to get the languages out independently. Vmix is also capable of muxing MAB or even more busses into the output.
Thanks for the answers so far. I am still facing the same challenge. The main use case is to stream 4 or 5 live interpretation languages in parallel. Unfortunately my streaming provider does not support multiple audio channels so far.
If vMix could allow 5 or 6 streams in parallel with different audio busses, I could do what I want with one computer. Currently I have to send my video signal through NDI from one computer to another to use the second PC for streaming in additional languages. I am not interested in a high image quality, but mainly in the audio.
Feature Requests
