Rank: Guest
Groups: Guests
hi all,
if you are using the amazing LiveLan feature, i would like to share with you a script that work as a counter to see how many people are watching live.
so, this is a simple counter and the logic is a ".bat" file, running on loop, containing a PowerShell script that is showing all "Established" connections to the port 8088 (default port for Web Controller).
It updates every 5 seconds and save the information on a ".csv" file that can be imported as an Excel/CSV Data Source.
This worked for me on W10 and W11
1. Start stream to LiveLan;
2. Copy the code bellow and save it on a ".bat" file;
:loop PowerShell -NoProfile -ExecutionPolicy Bypass -Command "Get-NetTCPConnection -Localport 8088 -State Established | Measure-Object -Line | Export-Csv -Path C:\stats.csv" timeout 5 cls goto loop
3. You can change the location of "stats.csv" by changing above "C:\stats.csv" to whatever you want to locate your file;
4. Run your ".bat" file and let it work, it can be minimized (if you get a red error is just because you don't have any established connection, make sure you pasted the code correctly, if yes don't worry, let it work even so);
5. Go to "Data Sources Manager", click "+" and choose "Excel/CSV";
6. Write whatever name you want, click "Browse", find the "stats.csv" file on root of C Drive;
7. Click Use first row as Column names and "OK"
There you have the information about how many lines (viewers) are connected;
hope it helps your production,
cheers
melody
 1 user thanked Guest for this useful post.
