emilt
#1 Posted : Friday, March 18, 2022 8:26:41 AM(UTC)
emilt
No
I've seen solutions that come close to what I'm trying to achieve but it doesn't quite saolve the issue.
I have a camera with two audio inputs. It connects to the computer using a blackmagic mini.
I'm controlling vMix with a streamdeck and want to be able to mute one of those tracks without muting the other.
And I also want to get a feedback (activatrors) telling me wheter this channelk is muted or not.
Unfortunately I can't just add the same blackmagic input twice, as the sound on the second input then has immense dropouts.
I believe there is no solution to this issue currently?
mtone
#2 Posted : Friday, March 18, 2022 9:00:19 AM(UTC)
mtone
if you have the two channels as one stereo input and you dont mind using two busses you could probably assign the left audio channel to buss A and right channel to Buss B in the channel matrix and then just mute either buss as needed ?
nidarosvideo
#3 Posted : Saturday, March 19, 2022 12:54:06 AM(UTC)
nidarosvideo
Norway
Ah! This is why I regard this forum as the best support forum I've ever seen.
Had some bug-issues with the Buses not showing yesterday but that is working now and then your solution is of course the perfect fix.
I've tested. It works. Thank you.
