Second Computer as backup machine.
Hi, let's say I'm doing a livestream and I want do have a second PC as a backup. I have the exact same vMix file on two diffrent Computers. Computer-A ist streaming to my main streaming server and Computer-B is streaming to the backup server Is ist possible to synch two instances of vMix on these two diffrent computers. So if I click input-1 on Computer-A, input-1 is also selected on Computer-B. And if I click on fade it will also performe a fade on B. And so on.
Is there a way? I didn't find on
Thanks!
Joined: 1/25/2019(UTC) Posts: 335  Thanks: 24 times Was thanked: 87 time(s) in 67 post(s)
yes, you can do this with central control. its a software between midi controls, fader banks, streamdecks etc. and vmix (or others) and it can send all commands to one or more vmixes in parallel https://centralcontrol.ioi use it to control cloud vmixes.
Thank you. I know centralcontrol. I use it to control vMix via a streamdeck and work with ATEM supersource. But I didn't know that centralcontrol can receive commands from one instance of vMix and send them to another.
How do you do this? With Tiggers?
i think everyone, use second computer as a backup...
