Feature Requests
CutDirect on Mix 2 through 4 and/or Mix 2 through 4 preview
The thing that I really want is a second multi-viewer that could have Preview/Program of Mixes 2 through 4 that I can send to a FullScreen output.
The runner up would be to send the preview of a Mix to another Input to build that as a layered Input.
The next thing would be to be able to CutDirect on the mixes 2 through 4 so that I could use Mixes 2 and 3 as my camera program and preview. So my buttons to put a camera in preview on Mix2 would also put it into Mix3 program so that Mix3 is preview of Mix2. The problem then is that hitting cut doesn't follow the Mix2 preview properly with Mix3. If I could CutDirect everything in Mix3 it would make it all work since the preview of Mix3 would always stay as the program of Mix2.
Joined: 12/27/2012(UTC) Posts: 5,513  Location: Belgium Thanks: 317 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: MacInnes Events  The thing that I really want is a second multi-viewer that could have Preview/Program of Mixes 2 through 4 that I can send to a FullScreen output.
like this ?
Sure, like that. I couldn’t figure out how to pull a preview from the extra mixes yesterday. Can you show me how your script works? Also does it constantly update or do you have to run the script to update?
Originally Posted by: MacInnes Events  Can you show me how your script works? Also does it constantly update or do you have to run the script to update? No I can not, sorry, as it was commissioned it constantly updates to changes regardless of how many of the available mixes are used
Joined: 12/28/2021(UTC) Views messages in topic : 8  Location: London Thanks: 1 times
I can tho - Let me know if you can't get what you want using this.
Joined: 9/22/2020(UTC) Posts: 44  Thanks: 3 times Was thanked: 5 time(s) in 5 post(s)
Using PlayLIVE Script on his Youtube channel (go and subcribed!!!) Thanks so much :)
Changed the target address to the following to get the other Mix :)
Mix2 Active = /vmix/mix/active Mix2 Preview = /vmix/mix/preview
Mix3 Active = /vmix/mix[2]/active Mix3 Preview = /vmix/mix[2]/preview
Mix4 Active = /vmix/mix[3]/active Mix4 Preview = /vmix/mix[3]/preview
 1 user thanked Howlswolf for this useful post.
Feature Requests
