Joined: 9/20/2014(UTC) Posts: 3 Location: Las Vegas NV
help with how to live stream to mobile? our current system is vMix / windows7/ red5 server need to live stream to mobile what hardware do we need to make this happen (transcoder) i presume / we do not want to go through a CDN as we intend on broadcasting 24/7 and cant afford the bandwidth. thanks Gene gene@genewoods.com
Joined: 2/9/2013(UTC) Posts: 266 Location: Katy, Texas
Have you looked at new.livestream.com as your CDN. Their pricing model is a flat monthly fee with unlimited bandwidth.
genewoods3 wrote:help with how to live stream to mobile? our current system is vMix / windows7/ red5 server need to live stream to mobile what hardware do we need to make this happen (transcoder) i presume / we do not want to go through a CDN as we intend on broadcasting 24/7 and cant afford the bandwidth. thanks Gene gene@genewoods.com I broadcast 24/7 with www.inacdn.com to all devices and they are awesome.
Thanks: 5 times Was thanked: 18 time(s) in 18 post(s)
Hello
Better to use a CDN it will cost you nothing compare to if you must build all these system by yourself
New.livestream.com is what we use
Several oter CDN are available, please compare what can fit your need and budget
C.
