rags89
#1 Posted : Thursday, March 3, 2022 4:38:09 PM(UTC)
rags89
India
It has been happening from yesterday that the program itself is running in the background and not be able to do anything in the application. The best part is all the shortcuts are still working when this happens.
The same issue continue even after reinstalling and after installing vmix 25beta
richardgatarski
#2 Posted : Thursday, March 3, 2022 6:48:39 PM(UTC)
richardgatarski
It is unclear what you mean by "freezes"
Check that there are no vMix confirmation windows hidden behind windows or on other screens.
Another cause can be that you have a Browser input with mouse enabled.
rags89
#3 Posted : Friday, March 4, 2022 3:57:50 PM(UTC)
rags89
India
By freezing I meant the application is not responding to any mouse clicks and the contents are frozen including the audio metering.
This has happened to all the servers with a rtx3090 graphics card and that even the server which was on a different location faced the same issue.
RiiZ
#4 Posted : Saturday, November 26, 2022 12:21:03 AM(UTC)
RiiZ
Denmark
Did you ever find a solution for this problem? I've been experiencing the same the last few weeks.
Upgraded both vMix version and Nvidia 2080RTX drivers, but still the same problem.
Any advice?
darktur
#5 Posted : Thursday, August 15, 2024 2:58:18 AM(UTC)
darktur
India
This is the exact discription of my problem as well still cant seem to find a sloution? Did you ever find it?
Please let me know it will help a lot
Luis70
#6 Posted : Thursday, August 15, 2024 6:42:53 AM(UTC)
Luis70
Grenada
Maybe you should check in the settings of vmix and make sure you have the Nvidia card selected in the Performance tab....
