JohnnyBG
#1 Posted : Monday, February 21, 2022 10:18:11 AM(UTC)
JohnnyBG
Not sure what I am doing wrong. I created a few shortcuts for my Stream Deck. I did this by editing two old shortcuts. They test out just fine. I used input 1 and input 2 for the two edited shortcuts. They test out just fine including some activators. I then saved the vMix preset with the two edited shortcuts. I closed out vMix and restarted with the vMix preset. The two edited shortcuts show one to be correctly edited, but the other one is the same as it was before editing.
To describe my changes (or edits): The one that will not save correctly had input 7, but after editing it is set as input 2. After saving and rebooting, it reverts back to input 7.
Am I doing something wrong? Shouldn't the edited shortcuts be saved after saving the preset?
