Hi, try this app. I hope for feedback. https://github.com/krinteron/vmix-title-controllerINSTALLYou need to install node.js https://nodejs.org/en/download/Next, you need to download the repository with the title controller. https://github.com/krint...hive/refs/heads/main.zipVia the command line, go to the directory with the title controller. Enter commands: npm install npm run build npm run start Done, you can go in the browser to the address http://localhost:8000/ *Don't close the command line *Don't forget to share the titles folder: -vmix_store --hrip_photo --titles *After all, you can also write a bat file to automatically start the application Something like: cd "C:\path_to_projectdir" npm run start
Joined: 2/28/2021(UTC) Posts: 15  Location: São Paulo Thanks: 2 times Was thanked: 11 time(s) in 5 post(s)
Hi i wanna try it But i don´t know how to install your app. Don´t have and Exe. file?
 2 users thanked kaduramos for this useful post.
Thanks: 2 times Was thanked: 7 time(s) in 6 post(s)
 1 user thanked chococrispis35 for this useful post.
Originally Posted by: chococrispis35  How install?????
thanks You need to install node.js https://nodejs.org/en/download/Next, you need to download the repository with the title controller. https://github.com/krint...hive/refs/heads/main.zipVia the command line, go to the directory with the title controller. Enter commands: npm install npm run build npm run start Done, you can go in the browser to the address http://localhost:8000/ *Don't close the command line *After all, you can also write a bat file to automatically start the application Something like: cd "C:\path_to_projectdir" npm run start
Is there a demo video to see how it should work
Could make a video to show to install it? Step by step please?
