JejeSwag
#1 Posted : Thursday, February 10, 2022 7:10:56 AM(UTC)
JejeSwag
Was thanked: 13 time(s) in 4 post(s)
Jecontrol.
This software allows you to control the Vmix Color Correction remotely in your network.
You can thus deport the task of colorimetry to your digital imaging technician chief / director of photography during your production,
It will get access to the different color wheels, saturation, luminance, hue.
Jecontrol also adds new features, like :
— 'cc off' button to disable temporally the color correction.
— color slider to control RGB individually in the same interface of color wheel.
— inputs link to link inputs selection to a Vmix output, to create an output monitoring.
& more in coming !
For installation, you install the software on the pc running Vmix and Jecontrol will create a server on your local network ! You can then access the interface on any computer on the same network !
You can download, and get more information on the website : https://www.jeonware.com/jecontrol
Hoping that this software can help you in your future productions !
thanks 1 user thanked JejeSwag for this useful post.
omnisound on 8/19/2022(UTC)
omnisound
#2 Posted : Friday, August 19, 2022 11:57:52 PM(UTC)
omnisound
Good job ! It's now possible to do a work place for a light vision mixer on productions.
Thank you !
