dsolomon
#1 Posted : Tuesday, February 8, 2022 6:40:54 PM(UTC)
dsolomon
I work with 5-10 clients a night, all 30 minutes shows. To be sure I record them all, I separate them into 30 minute segments. However, to make it work, the recorder has to be started right at the top of the hour. if I miss it, it will throw off my 30 minute recording segments. Is there a way to create a timer that will start it on time? For instance, every Wed & Thur at 8pm and every Tuesday at 2pm? That would be a big help.
#2 Posted : Tuesday, February 8, 2022 7:15:00 PM(UTC)
https://forums.vmix.com/...a-shortcut-at-a-set-time
https://forums.vmix.com/...273-Do-at-a-certain-time
https://forums.vmix.com/...e-Countdown-and-Recorder
https://forums.vmix.com/...ng-for-Dummies#post74242
https://www.vmix.com/kno...-vmix-support-scheduling
