Joined: 4/4/2016(UTC) Posts: 235  Location: Not Los Angeles CA Thanks: 86 times Was thanked: 28 time(s) in 23 post(s)
Now that I know what a Mix Input is I want more, heheh.
Is it possible to have 10 mix Inputs?
Production use - I want to use multiple layers up to 10 each with a mix Input on each layer.
I will try to do a mock up using what exists currently with Mix Inputs on as many layers as possible That way you can visualize what I am discussing.
 1 user thanked RichShumaker for this useful post.
Joined: 11/17/2020(UTC) Posts: 10  Location: New Delhi Thanks: 9 times
Joined: 7/27/2022(UTC) Posts: 31  Thanks: 11 times Was thanked: 2 time(s) in 2 post(s)
