Two playlist for two streams
Joined: 11/8/2021(UTC) Posts: 11  Location: new delhi Thanks: 1 times
I am able to stream two different outputs in same vmix. But, when it comes to playlist, i am able to set only one playlist for one output streaming.
I want to use second playlist for second stream from same vmix. It it possible or i am missing something?
I want to use second playlist for second stream from same vmix. It it possible or i am missing something? Playlist is directly tied to the output, try with lists or use second computer
----------- OK thanks. I thought when vmix have the facility for two output stream, then it should also have something for two playlist for both outputs.
Originally Posted by: ravi.singh  Originally Posted by: doggy  Originally Posted by: ravi.singh  Hi,
----------- OK thanks. I thought when vmix have the facility for two output stream, then it should also have something for two playlist for both outputs. Like creating mutiple different (3) productions on one machine ?
