NDI
NDI & VMIX with ZOOM
Joined: 4/23/2020(UTC) Posts: 15  Location: Thornhill Thanks: 1 times
Can't seem to find a reason for this. Wondering if I need to dive deeper into network settings. We are using VMIX and feeding the main output to ZOOM laptops via NDI There are two laptops beside each other and sometimes we start to see some minor lag or stutter. If we go to NDI settings and tell it use VMIX output 2 instead of 1 it fixed the issue. However, the laptop beside it which is on that same output doesn't have an issue. The problem can and has happened on both laptops sometimes using the same VMIX outputs and sometimes different. The problem also seems to be intermittent as well. I know the PCs themselves are optimized and VMIX is doing just fine and nothing to report along that end. We are on a 10Gb UNIFI backbone and each computer is being fed hard wired to a separate Gigabit port. I've put a picture in just to show the two laptops etc. I don't think it helps much but trying to be thorough. If anyone has any input on this I would appreciate it.  IMG_1856 (1).jpg (2,197kb) downloaded 2 time(s).
NDI
