richardgatarski
#1 Posted: : Friday, October 3, 2014 10:20:30 AM(UTC)
richardgatarski
Sometimes vMix does not find cameras and audio inputs that are defined in the preset file becuase the hardware is in a different PCIe-slot, USB-port, or that the preset was configured in another PC, etc. That vMix nowadays makes the input "offline" instead of removing it is a great improvement.
It would be even greater if vMix for missing devices asked "Change, make offline or remove Input?"
