Cyril81
#1 Posted : Tuesday, January 18, 2022 8:52:19 PM(UTC)
Cyril81
Bonjour à tous,
Is there a way to just press a key on the keyboard, to change the score from 0 to 15 then 30 then 40 ?
Merci de votre aide.
#2 Posted : Wednesday, January 19, 2022 2:20:34 AM(UTC)
Originally Posted by: Cyril81 Go to Quoted Post
Bonjour à tous,
with one key or multiple ?
for one key a little script would do that
Cyril81 on 1/20/2022(UTC)
MartLeib
#3 Posted : Wednesday, January 19, 2022 4:51:46 PM(UTC)
MartLeib
You have been a member since:: 2/23/2017(UTC)
Estonia
I would just use Data source for it, create an Excel file which has title row "Score" and each row has score 0 15 30 40 AD and add it to vMix Data Source, then create shortcut using function DataSourceNextRow and configure your title to use that Data Source.
You can input same file twice to get scores for both players. For AD I would create seperate buttons since other player must have blank score when Advantage is shown.
You can also jump to certqin Data Source row using shortcuts.
thanks 1 user thanked MartLeib for this useful post.
Cyril81
#4 Posted : Thursday, January 20, 2022 1:31:22 AM(UTC)
Cyril81
Thanks to all 2. Specially Martin (?) I will try this solution.
As for the scripts, I will look at it later. (not very used to it yet)
