richardgatarski
#1 Posted : Tuesday, January 11, 2022 2:50:37 AM(UTC)
richardgatarski
It is already possible to enable NDI output for Cameras / Calls / Audio Input as well as the Outputs on the settings page. It would for sure be nice with an option to also enable NDI output from Fullscreen and Fullscreen2. Not sure if the resource limit that Martin likes to explain now and then in the vMix FTLS applies. But I thought it might be worth asking...
We are sort of moving from HDMI to NDI in our setups. We have been using the two available Fullscreen outputs for various uses, including for talent monitor, backdrop TV, and teleprompter screen. One way to get those Fullscreens to NDI is to purchase two more HDMI-NDI encoders.
I also realized that I could actually just connect the graphic card's HDMI outputs to two HDMI inputs on our capture cards, and enable NDI output from those "cameras". But this implies the need for a capture card, and a splitter if you want some kind of traditional output as well.
(side request: separate the enabling from Cameras, Calls, and Audio Inputs - don't see the point of lumping them together...)
nikosman88 on 1/11/2022(UTC)
Peter Berglund
#2 Posted : Tuesday, January 11, 2022 10:18:17 PM(UTC)
Peter Berglund
Sweden
+1
