321actionvideo
#1 Posted : Saturday, January 8, 2022 7:49:07 AM(UTC)
321actionvideo
I have a simple GT titler with no animations, and from time to time, it doesn't update the data correctly. I use the GT titler as the text looks better than the legacy titler. So to give more info on the issue, I am currently using data sources from a CSV file. When I right-click on input and select title editor, it all has the correct info, but for some reason, GT Titler is not updated on the screen, almost like the live button is off, but I always leave it on. If I reload the input by clicking the cogwheel, and change, and reload the same gtzip file, it will correct itself. So Please let me know how to fix this as it is quite annoying to have the wrong data on the screen and have to reload the input each time it happens.
