Blakesheaven
#1 Posted : Friday, December 24, 2021 8:18:52 PM(UTC)
Blakesheaven
We get all our music/lyrics from songselect.ccli.com and are using "worshipextreme.com presenter" (WEP) to control the lyric slides... WEP is fully integrated with SongSelect to pull the lyrics directly into playlists. We use vMix to stream and presentation to front monitors.
vMix, not having direct integration to the likes of Songselect to easily pull down songs and an easy way to control them is a huge hole in vMix for church services because this means that we end up having to use two apps.
Can you have a look at WEP and Songselect and consider adding an input type that can pull lyrics directly into an input that is controllable by something like the image slide controller.
Some simple templates should be provided like "full screen", "lower third", etc and ability to have transparent, black, white backgrounds should be included.
NB: The image slide controller needs improvement. Make thumbnails auto-fit the whole resizable window so text can be read. Make it more obvious which the current slide is.
