freefishday
#1 Posted : Thursday, December 23, 2021 11:20:07 PM(UTC)
freefishday
China
As Full NDI takes up too much bandwidth, I'd like to use NDI HX in vMix outputs/NDI/SRT setting.
It seems Full NDI by default in vMix outputs, no way to change.
How to make vMix output NDI HX?
sinc747
#2 Posted : Sunday, December 26, 2021 12:21:43 PM(UTC)
sinc747
Was thanked: 207 time(s) in 173 post(s)
Originally Posted by: freefishday Go to Quoted Post
no way to change.
Yes, no way to change in vMix. NDI/HX is traditionally used by hardware manufacturers (like cameras or encoders).
- Tom
fluozh
#3 Posted : Sunday, December 26, 2021 4:16:15 PM(UTC)
fluozh
Japan
Was thanked: 14 time(s) in 11 post(s)
You can convert NDI|FB(Full Bandwidth) to NDI|HX by using NDI Bridge Local mode in NDI Tools.(or Hardware converters)
NDI Bridge PC should be able to convert H.264/H265(HEVC) stream by GPU though(generally GPU encode only supports up to 2-3 streams per board).
Also NDI|HX receiver side needs to decode NDI|HX H264 or H265 stream by GPU or CPU, so NDI|HX may impact receiver's performance insted of network throughput.
thanks 1 user thanked fluozh for this useful post.
stergi on 3/3/2023(UTC)
