jpetrie
#1 Posted : Thursday, December 23, 2021 6:06:37 AM(UTC)
jpetrie
A handful of my fellow vMix operators and I are feeling like we may be experiencing the Mandela Effect. We all swear we remember a time ~6 or more months ago that presets on a countdown input were able to be selected and launch different countdown timers without adjusting the settings. (I suspect it may have worked in V23 and was broken in V24, but others think it was working in V24.)
I tried searching this forum for "countdown presets" and did not find any similar posts, so I hope this isn't a repeat, but thought it might be worth trying out, since I've been using vMix for so long now, but haven't really joined in the forums until now.
(In trying to reproduce the steps to write them down, vMix 25 hung for a bit while trying to add a new GT Timer input, I've not seen that happen before!)
Steps to reproduce:
Add GT Timer input
Open the Title Editor
Hit Settings to set the time
Hit + to add a preset
Hit Settings to set another time
Hit + to add preset
Select 1st preset and see that the text updates
Press Play to start countdown and see that the countdown settings most recently set overwrites/ignores anything typed in the Timer.Text area
I hope this helps!
