Feature Requests
Fullscreen MultiView design
I think it would be awesome to add or change the design of the MultiView on the Full Screen. Or add a feature to even create your own design and layout of it. Currently I think the view is lacking clarity of what input is in preview and what input is in program with only the top bar with input name being painted green or red. Most of MultiViews out there would offer some sort of all-around border/stroke painted white which would paint green/red when input is in program/preview. Only the top bar makes it confusing, specially when you are live and under influence of tons of other information, if the input is being used or not when you are glazing only the inputs, not the preview/program monitor. Also it would be nice if in this case the name of the input would be overlayed over the input so the layout of the MultiView would be true 16:9. Examples:  multiviewer_789_526_70_s.jpg (40kb) downloaded 3 time(s). professional-features-md.jpg (318kb) downloaded 2 time(s).
 1 user thanked JxM for this useful post.
Joined: 10/25/2018(UTC) Posts: 43  Location: Moscow Thanks: 8 times Was thanked: 4 time(s) in 3 post(s)
+1. You need the option "Remove extra thickness of fields and place names of inputs in the video area"
I guess there is no need for this to change? :(
Joined: 7/5/2019(UTC) Posts: 28  Location: Sydney Was thanked: 5 time(s) in 4 post(s)
Originally Posted by: JxM  I think it would be awesome to add or change the design of the MultiView on the Full Screen. Or add a feature to even create your own design and layout of it. Currently I think the view is lacking clarity of what input is in preview and what input is in program with only the top bar with input name being painted green or red. Most of MultiViews out there would offer some sort of all-around border/stroke painted white which would paint green/red when input is in program/preview. Only the top bar makes it confusing, specially when you are live and under influence of tons of other information, if the input is being used or not when you are glazing only the inputs, not the preview/program monitor. Also it would be nice if in this case the name of the input would be overlayed over the input so the layout of the MultiView would be true 16:9. Examples:  multiviewer_789_526_70_s.jpg (40kb) downloaded 3 time(s). professional-features-md.jpg (318kb) downloaded 2 time(s). +1. Also would be nice to have 2 MV layout options. I should note, you can partially re-create a multiview using a black colour input and using layers.
 1 user thanked carlofornasari for this useful post.
Joined: 3/28/2017(UTC) Posts: 70   Location: Haapsalu, Estonia Thanks: 75 times Was thanked: 3 time(s) in 3 post(s)
Thanks: 12 times Was thanked: 33 time(s) in 28 post(s)
Joined: 12/6/2022(UTC) Posts: 7  Was thanked: 2 time(s) in 1 post(s)
Thanks: 185 times Was thanked: 20 time(s) in 17 post(s)
Joined: 6/5/2020(UTC) Posts: 91  Location: Jakarta Thanks: 17 times Was thanked: 5 time(s) in 3 post(s)
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: gpdipalmerahtimur  Or check the latest v26 opdate ( has now also a preview input ! )
Originally Posted by: doggy  Originally Posted by: gpdipalmerahtimur  Or check the latest v26 opdate ( has now also a preview input ! ) Yeah you are right it is very handy, but a simple object like Master Audio Meter overlay would be very helpful for Audio Monitoring to build Custom Made MultiView. Probably can be added as Option on Output as Input that can be ticked if we want to display Audio Meter on that Output Input.
Feature Requests
