Schnorbert
#1 Posted : Friday, December 10, 2021 10:16:08 PM(UTC)
Schnorbert
Germany
Hello, today I sent out an RTMP stream, that was running for almost 2 hours, until it suddenly stopped.
After restarting the stream and restarting the software it still didn't work.
I got a new Stream-URL and stream key and it still didn't work. After restarting the whole Computer it continued working until the end of the stream.
This is the log:
ffmpeg started on 2021-12-10 at 09:29:53
Report written to "C:\ProgramData\vMix\streaming\streaming1 20211210-092952.log"
Command line:
"C:\\Program Files (x86)\\vMix\\streaming\\ffmpeg.exe" -report -rtbufsize 128M -f dshow -i "video=vMix Video YV12:audio=vMix Audio" -codec:v libx264 -s:v 1920x1080 -pix_fmt:v yuv420p -threads 4 -bufsize:v 6000k -g:v 50 -preset:v veryfast -profile:v main -level:v 4.1 -b:v 6000k -maxrate:v 6600k -codec:a libfaac -b:a 128k -strict -2 -rtmp_flashver "FMLE/3.0 (compatible; vMix/23.0.0.66)" -f flv rtmp://origin-live-2-1.v-hub.live:1935/live/ff674538598b4ec5b75c15b1dcb78ff1/hyundai
ffmpeg version 2.8.git Copyright (c) 2000-2015 the FFmpeg developers
built with gcc 4.8.1 (rev2, Built by MinGW-W64 project)
configuration: --enable-gpl --enable-version3 --enable-libx264 --enable-zlib --enable-libfaac --enable-nonfree --cpu=i686 --enable-nvenc
libavutil 55. 2.100 / 55. 2.100
libavcodec 57. 3.100 / 57. 3.100
libavformat 57. 2.100 / 57. 2.100
libavdevice 57. 0.100 / 57. 0.100
libavfilter 6. 9.100 / 6. 9.100
libswscale 4. 0.100 / 4. 0.100
libswresample 2. 0.100 / 2. 0.100
libpostproc 54. 0.100 / 54. 0.100
Guessed Channel Layout for Input Stream #0.1 : stereo
Input #0, dshow, from 'video=vMix Video YV12:audio=vMix Audio':
Duration: N/A, start: 2331.333000, bitrate: 1536 kb/s
Stream #0:0: Video: rawvideo (YV12 / 0x32315659), yuv420p, 1920x1080, 25 tbr, 10000k tbn, 25 tbc
Stream #0:1: Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s
[tcp @ 027ab700] TCP Buffer has been set to 15320064 bytes
[libx264 @ 05227920] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 AVX2 LZCNT BMI2
[libx264 @ 05227920] profile Main, level 4.1
[libx264 @ 05227920] 264 - core 144 - H.264/MPEG-4 AVC codec - Copyleft 2003-2014 - http://www.videolan.org/x264.html - options: cabac=1 ref=1 deblock=1:0:0 analyse=0x1:0x111 me=hex subme=2 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=16 chroma_me=1 trellis=0 8x8dct=0 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=4 lookahead_threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=1 keyint=50 keyint_min=5 scenecut=40 intra_refresh=0 rc_lookahead=10 rc=abr mbtree=1 bitrate=6000 ratetol=1.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 vbv_maxrate=6600 vbv_bufsize=6000 nal_hrd=none filler=0 ip_ratio=1.40 aq=1:1.00
Output #0, flv, to 'rtmp://origin-live-2-1.v-hub.live:1935/live/ff674538598b4ec5b75c15b1dcb78ff1/hyundai':
Metadata:
encoder : Lavf57.2.100
Stream #0:0: Video: h264 (libx264) ([7][0][0][0] / 0x0007), yuv420p, 1920x1080, q=-1--1, 6000 kb/s, 25 fps, 1k tbn, 25 tbc
Metadata:
encoder : Lavc57.3.100 libx264
Stream #0:1: Audio: aac (libfaac) ([10][0][0][0] / 0x000A), 48000 Hz, stereo, s16, 128 kb/s
Metadata:
encoder : Lavc57.3.100 libfaac
Stream mapping:
Stream #0:0 -> #0:0 (rawvideo (native) -> h264 (libx264))
Stream #0:1 -> #0:1 (pcm_s16le (native) -> aac (libfaac))
Press [q] to stop, [?] for help
frame= 17 fps=0.0 q=0.0 size= 0kB time=00:00:00.63 bitrate= 5.0kbits/s
frame= 30 fps= 30 q=25.0 size= 295kB time=00:00:01.15 bitrate=2099.2kbits/s
frame= 43 fps= 28 q=18.0 size= 385kB time=00:00:01.64 bitrate=1923.1kbits/s
frame= 55 fps= 27 q=16.0 size= 557kB time=00:00:02.15 bitrate=2119.8kbits/s
frame= 68 fps= 27 q=19.0 size= 842kB time=00:00:02.66 bitrate=2589.4kbits/s
frame= 80 fps= 26 q=17.0 size= 1311kB time=00:00:03.15 bitrate=3405.6kbits/s
frame= 93 fps= 26 q=16.0 size= 1437kB time=00:00:03.66 bitrate=3211.4kbits/s
frame= 106 fps= 26 q=13.0 size= 1725kB time=00:00:04.17 bitrate=3382.1kbits/s
frame=153592 fps= 25 q=18.0 size= 4268058kB time=01:42:23.63 bitrate=5691.1kbits/s
frame=153605 fps= 25 q=18.0 size= 4268437kB time=01:42:24.12 bitrate=5691.1kbits/s
frame=153617 fps= 25 q=18.0 size= 4268823kB time=01:42:24.63 bitrate=5691.2kbits/s
frame=153630 fps= 25 q=22.0 size= 4269203kB time=01:42:25.15 bitrate=5691.2kbits/s
frame=153643 fps= 25 q=19.0 size= 4269712kB time=01:42:25.66 bitrate=5691.4kbits/s
frame=153655 fps= 25 q=18.0 size= 4270075kB time=01:42:26.17 bitrate=5691.4kbits/s
frame=153668 fps= 25 q=19.0 size= 4270545kB time=01:42:26.66 bitrate=5691.6kbits/s
frame=153681 fps= 25 q=22.0 size= 4271066kB time=01:42:27.17 bitrate=5691.8kbits/s
frame=153693 fps= 25 q=18.0 size= 4271342kB time=01:42:27.68 bitrate=5691.7kbits/s
frame=153706 fps= 25 q=18.0 size= 4271798kB time=01:42:28.17 bitrate=5691.9kbits/s
frame=153719 fps= 25 q=21.0 size= 4272224kB time=01:42:28.71 bitrate=5691.9kbits/s
frame=1537
Specs:
Processor: Intel(R) Xeon(R) E-2278G CPU @ 3.40GHz, 3408MHz, 8 Cores,
GPU: NVIDIA Quadro P4000
Any explanations on why this happened and how to avoid it in the future?
Thank you in advance!
