Soapm
#1 Posted : Friday, December 10, 2021 10:55:45 AM(UTC)
Soapm
We’re a small church and use vmix and all our audio/video computing from a single PC (it was all we could do to afford the one PC). Everything works fine until we play audio from vmix (or from the computer) into the sanctuary via the 3.5mm headphone jack on the computer. What happens is the output from our computers 3.5mm headphone jack is fed into the mixer, which is sending it back to the computer on the USB which vmix picks up as incoming audio and presto, we have a feedback loop.
What I’m trying to understand is, when playing audio or video, how do we set that particular input so that it’s outputting audio only (outputting to our streams, outputting to the sanctuary via 3.5mm headphone jack) but will ignore anything coming in on the USB connection from the mixer?
Inversely, when using a regular camera input which takes its audio via USB from our mixer, how do I keep that audio from being outputted via the 3.5mm headphone jack on our PC so it won’t be feed back into the mixer?
Soapm
#2 Posted : Friday, December 10, 2021 5:09:41 PM(UTC)
Soapm
Automatically mix audio is the setting I need to understand how to work.
So if I'm playing a input that contains a video with sound, I disable automatically mix audio and it should remove the sound from the mixer but allow the sound from the video to be played both in our in house mixer and on the streams? Am I getting close?
dmwkr
#3 Posted : Saturday, December 11, 2021 10:39:19 PM(UTC)
dmwkr
Was thanked: 153 time(s) in 137 post(s)
Audio Outputs and Buses are the relevant topics.
There are more videos in the Audio series from Tim. Maybe these should be your starting point.
zenvideo
#4 Posted : Sunday, December 12, 2021 3:41:33 AM(UTC)
zenvideo
Originally Posted by: Soapm Go to Quoted Post
... What happens is the output from our computers 3.5mm headphone jack is fed into the mixer, which is sending it back to the computer on the USB which vmix picks up as incoming audio and presto, we have a feedback loop.
Personally, I'd try to solve this by using a hardware audio mixer where you can create different (aux) output mixes, and therefore ensure that the output mix being fed to vMix doesn't include the audio from the video that's being played (whilst also generating a different output mix with everything that should be fed to the sanctuary). If your current audio mixer can't do this then you could add another very small mixer (no more than two channels are needed) to take (a) the feed from the vMix PC (so it doesn't go into the main mixer and get sent back to vMix) and (b) a feed from the main mixer, and then you can create a dedicated mix for the sanctuary.
Alternatively, if you need to feed the video playback audio into the mixer, and can't create two different mixes from it, then it's possible to let the hardware mixer create the "master" mix for vMix, and to break the feedback loop by removing the video playback audio from vMix's internal Master audio bus.
Either way, you need to create a dedicated "clean feed" output of the video playback audio to connect to an external mixer. To get that clean feed you will need another audio output device for the PC, something like the Behringer-UCA222 USB interface. Then, for the video playback input in vMix, you will change the audio routing so that it doesn't get sent to the Master audio bus (disable the 'M' button), and instead send it to an otherwise unused audio Bus (one of the A to G busses). Finally, in the vMix settings, select the new audio output device as the destination for the audio group that you've used, and now you'll have a "clean feed" signal that can go to an external mixer.
What will happen now is that the external mixer will handle all the audio mixing, including the feed of the video playback, and that mix will be sent both to vMix (with no feedback loop) and the sanctuary.
Alternatively, if you're going down the other route of using a second mixer to combine the video playback audio with the rest of the audio coming from the main mixer, you will still need to set up the "clean feed" output as above, but this time you need to keep the 'M' button on for the video playback input so that vMix adds the video playback audio into the vMix Master output mix.
