Deinterlacing in video delay
Thanks: 38 times Was thanked: 39 time(s) in 35 post(s)
I just tried Vmix 14 and I had high hopes in the new deinterlacing system.
But I was a little bit disappointed, when I found out that the video clips create with video delay still have the same "double contour blend deinterlacing problem".
Master Frame Rate is set to PAL 50p Output Size is set to 1920x1080
I'm recording a 1080i50 source with video delay (10 seconds clips)
Everything looks smooth and bob (or discard...I don't see Bob as an deinterlacing choice anymore) seems to work with the live input.
But when I save a clip, the clip is only playable with the very bad blend deinterlacer.
How can I use bob or discard or anything better than blend for saved clips?
Are there any settings I haven't found yet?
I hope someone can help me out.
Thx
