Simsyuk
#1 Posted : Sunday, November 21, 2021 1:58:48 AM(UTC)
Simsyuk
Was thanked: 24 time(s) in 19 post(s)
I'm planning in purchasing a 5mb Jennov CCTV PTZ camera for my needs (broadcast some night vison events) and I wondered if the PTZ can be controlled by vMix. I currently planning to purchase the 4k version (as that gives me the PTZ options) but I don't want to spend $350 on something that won't work for my needs.
Can anyone tell me if this is possible, I've noticed under the PTZ it has device name and IP address.
Thanks in advance.
#2 Posted : Sunday, November 21, 2021 10:58:00 PM(UTC)
@ Simsyuk
It is highly unlikely that a CCTV PTZ camera will be controllable by the vMix PTZ Control feature.
Typically, such cameras will use the ONVIF protocol for control, which vMix does not support.
Basically, only the VISCA UDP and VISCA over IP protocol is supported by vMix:
https://www.vmix.com/sof...ardware.aspx#ptz-cameras
Simsyuk on 11/26/2021(UTC)
Simsyuk
#3 Posted : Friday, November 26, 2021 6:57:36 PM(UTC)
Simsyuk
Thank you.
