Joined: 4/9/2020(UTC) Posts: 7  Location: montréal Thanks: 4 times
when i connect to vmix call with safari or google chrome using ipad or iphone, i am unable to hear speaker sound if i do not use earphone. I didn't have this problem with ios 14. does anyone have the same problem as me. what is the solution
Same.
I am using a RODE NTG USB and it is iOS certified. The device is both a microphone and audio output. We use it with other software like LiveU mobile and Larix broadcaster to get quality audio and send returns. Now both aren't working correctly. Only the ipad speakers will output sound and it's exceptionally low. Headphones connected do not help.
