agistchau
#1 Posted : Monday, November 15, 2021 11:58:01 PM(UTC)
agistchau
Hi fellas,
A client wants me to use his own graphics for titles and lower thirds. they Asked me how I want the files (open files, PNG, etc..) .. I don't have a clue. What is the best file format of those things for implanting it into vMix? What should I ask them for?
Another question, I'm streaming 2 speakers Infront of a green screen. The clients wants to use his still graphic on the green screen. They asked me which size and format do I need this file for implanting it on green screen via vMix..?
Thanks for help.192.168.0.1 router login 192.168.1.1
#2 Posted : Tuesday, November 16, 2021 2:41:29 AM(UTC)
PNG's , production frame size (None image parts transparent for the titles) then you dont have to tweak/reposition things
richardgatarski
#3 Posted : Tuesday, November 16, 2021 3:46:43 AM(UTC)
richardgatarski
also, if you will zoom into the still graphic used for the green screen you should consider having that still in a higher resolution than the production frame size.
