	Feature Requests
	Axis Streaming Assistant Compatibility
                We stream from a number of Axis IP security cameras, and Axis created a piece of software called the "Axis Streaming Assistant" (http://www.axis.com/products/streaming_assistant/) that makes the feeds available to software like Flash Media Live Encoder, Ustream Producer, Livestream Producer, etc. However, for some reason the axis streaming assistant "cameras" do not show up as available in Vmix. This wouldn't be an issue if Vmix was natively handling the RTSP streams better, but as mentioned in my earlier post to the general discussion board, I'm experiencing random connection errors in Vmix that don't occur when letting ASA handle the stream.
  Since other programs are able to "see" the ASA cameras, I'm hoping this might be an easier feature request to make happen. Thanks for your help!
	Feature Requests
