AF2022
#1 Posted : Friday, November 12, 2021 11:37:36 AM(UTC)
AF2022
Japan
Just started with Vmix after years of streaming with wirecast and then livestream and an atem, and I have a few things I would like some help with around Audio.
I run a weekly live 30 minute live broadcast for kids that involves a lot of songs and sound effects and a live performer (or 3 in non covid times!)
I have been running a pretty convoluted set up for audio that has audio fired from a ipad, into a mixing desk, that goes into the room for the performer and to a camera for mixing with the performer miced with a shotgun. Sometimes the performer has to sing along with a video as well.
The problem with this set up is trouble effectively monitoring the levels and balance, plus sometimes echo from the room.
I am thinking that with vmix I can bus the audio from video sections out via a usb interface like the berringher umc204hd, and back into the room.
where the performer would sing along and then back through the camera with the visuals.
But I am concerned about latency of the whole system if someone else has experience of this kind of show i'd love to hear if there is an approach for an audio set up that I haven't considered?
mtone
#2 Posted : Friday, November 12, 2021 12:38:50 PM(UTC)
mtone
here is how i would set this up...
1. ipad audio into mixer..
2. performers microphone into mixer..
3. audio from the ipad routed out of mixer to room speakers using a monitor send or aux send on the mixing desk
4. main outputs of the mixer sent to the cameras audio inputs with correct balance set between between ipad and microphone
5. camera is captured into vMix (audio and video)
6. if you need videos playing from vMix to be heard in the room also.. route the video clips to an audio buss in vMix and output that buss from computer interface into the mixer. then you can raise the vMix level in the aux send of the mixer to the room speakers..
if have audio from ipad running through speakers and a mic in the room it will be difficult to totally avoid echo.. you could maybe try using headphones for the performer or point speakers towards the performer from other side of the room and use a cardioid microphone..
thanks 1 user thanked mtone for this useful post.
AF2022 on 11/12/2021(UTC)
AF2022
#3 Posted : Friday, November 12, 2021 12:49:47 PM(UTC)
AF2022
Japan
Thanks for that! That makes sense.
i'm going to set up like this next time. i'm a bit worried about latency between the video and the performer audio, but I guess ill set it up and see what happens.
Cheers for taking the time to respond!
mtone
#4 Posted : Friday, November 12, 2021 3:41:45 PM(UTC)
mtone
a benefit of sending all audio sources to the analog mixer is you have everything in one place and can then do one mix to the speakers using an aux send and a separate mix back to the camera for the stream.. (with this setup all audio for the stream is coming directly from the camera)
that isnt the cleanest signal path as the video clip audio goes out of computer, through analog mixer and camera back to vMix again. the benefit though is it helps avoid latency and should be easy to make adjustments to speakers or stream levels from one location.. if you want the images from the video clip to be in time with the performer singing you may have to apply some delay offset to the audio on the video clip before sending it out to the mixer..
as an alternative... if your audio interface has an internal mixer and at least a couple of inputs/outputs you may be able to connect directly to it instead of the analog mixer for a cleaner setup.. ie:
1. microphone and ipad go directly into audio interface.
2. add 2x audio inputs in vMix for the microphone and ipad
3. send the video clips audio to a vMix buss
4. use audio interface mixer software to adjust levels between microphone, ipad and the buss from vMix with the video clip audio. (reliant on the interface being used offering this feature)
5. use an output on the audio interface to connect to speakers and send the monitor mix created in the audio interface mixer.
6. use vMix to set levels between microphone, ipad and video clip for the main stream audio
7. adjust delay offsets in vMix as needed for different sources..
i cant picture in my mind exactly what delays would be needed using this setup but should be able to get everything aligned with some tweaking (i think).... :)
