Joined: 11/12/2021(UTC) Posts: 2  Location: Oklahoma City
Looking to upgrade from Vmix Basic HD 21.0.0 to Vmix HD 24. Will the settings and presets import in to the new version OK, or will I have to rebuild everything upon upgrading? Sorry I've searched the FAQ and forum, but couldn't find an answer.
Thanks: 10 times Was thanked: 4 time(s) in 4 post(s)
You will have no issue upgrading. The process is as simple as changing the license and restarting vMix. I would suggest exporting the settings anyway as a just in case, but moreso if your computer dies vs having issues upgrading the license.
Thanks for your input. You were right, no issues. Except for putting in the license key, I would have thought I had opened up the old version. I love it when things are just that easy.
