broadcastop
#1 Posted : Thursday, November 11, 2021 10:30:39 AM(UTC)
broadcastop
I spent some time combing the forums, but failed to find an answer to this one.
Can I run multiple control surfaces on one vMix machine? The hope is that we can have a TD running an Xkeys controller, and an A1 running an APC40 on the same machine with the audio mixer window broken out to a second display.
Thanks!
rudyengels
#2 Posted : Thursday, November 11, 2021 4:19:55 PM(UTC)
rudyengels
Was thanked: 25 time(s) in 18 post(s)
You can change the MIDI channel for the X-Keys controller (eg channel 2). The AP40 is using channel 1.
Selecting a custom MIDI Channel for X-Keys controllers
