GNP
#1 Posted : Friday, November 5, 2021 12:20:09 PM(UTC)
GNP
I am using three Canon XA15 cameras with vMix instant replay, including one wireless Hollyland Mars 400s Pro. When the wireless is not connected it works great with replay. However, when I connect the wireless unit I get an error message (below).
It had been working for the last few weeks.
What is the solution? Thank you!
Replay_RecordingStartStop.ReplayInput_ConfigureSources
Camera1: DeckLink Quad HDMI Recorder (1) 1 Camera frame rate must match Replay Session Format: Source: 333333 Replay: 333667
SportsNetUSA.net
#2 Posted : Saturday, November 6, 2021 4:49:59 AM(UTC)
SportsNetUSA.net
So everything worked including using the Hollyland Mars 400s Pro connected?
If not, what are the frame rates for your three (3) cameras and what do you have the frame rate set for in Instant Replay? Double check to make sure everything is the same.
The Hollyland unit may be outputting some frame rate that is slightly different than what the Canon XA15 is (60fps vs 59.94). I believe I've had that problem with a ParaLinx unit.
