shampton
#1 Posted : Thursday, October 28, 2021 1:49:10 AM(UTC)
shampton
We're experiencing some very long preset load times and was wondering if anyone had any suggestions (about 10 mins to load my current preset).
I sifted through some threads to glean what I could.
I cleared the caches on the Add Inputs...except image sequence; I don't see a 'clear' option on this tab.
There no external USB drives connected to the computer.
I did have a very large show preset that I started from, but I copied it, and then gutted it, and it's still taking the same amount of time; there's only 4 stingers in it now.
(I was thinking the stingers were what was bogging it down. The old stingers still show up in the Add Input section but they are not inputs in the actual preset...not sure how to purge those.)
Cheers!
