	Vmix Slows my internet to a crawl
                I test my internet speed and it's 250mbps download and 260 upload. As soon as I open vmix it goes down to 3mpbs/0.20. This happens on the two computers that run vmix. There are no other programs running.
                I just tested using two (2) different speed tests, and there was no difference in download/upload speeds with vMix open or vMix not running.
  Have you taken a look at Task Manager after you open vMix to see what other processes are running?
 Joined: 6/6/2016(UTC) Posts: 19   Location: The Netherlands
                Originally Posted by: SportsNetUSA.net  I just tested using two (2) different speed tests, and there was no difference in download/upload speeds with vMix open or vMix not running.
  Have you taken a look at Task Manager after you open vMix to see what other processes are running?  Got the same problem. But it is two years later. Ever got it solved?
