hidavid
#1 Posted : Tuesday, October 26, 2021 4:52:36 PM(UTC)
hidavid
Hello
I know this topic has been talked upon before but maybe somehow has found a solution or can point me into the right direction
With the new BM Studio Camera 4k Pro i've taken the plunge and bought into the BM Ecosystem. Did anyone find a way to transmit the Tally Signal out of VMIX onto (idealy multiple) new BlackmagicStudio Converters and into the camera?
Thank you
ggudnason
#2 Posted : Tuesday, October 26, 2021 7:26:44 PM(UTC)
ggudnason
Was thanked: 8 time(s) in 7 post(s)
The only thing I can think of is that you would have to create a custom tally system for this and embed the tally signal into the sdi coming from vmix. Blackmagic has a device for this. "Blackmagic 3G‑SDI Shield for Arduino". https://www.blackmagicde...rsabroadcast/accessories
Here is some info on how the tally works. https://1sourcevideo.com...How-ATEM-Tally-Works.pdf
What I have used for tally on vmix is a product called tallyarbiter. https://github.com/josephdadams/TallyArbiter
I tested that with the M5StickC and there is a code for that to work with tallyarbiter https://github.com/josep...Arbiter-M5StickCListener
So I am thinking that possibly with one blackmagic shield you could write custom code to interface with the tallyarbiter and embed the tally ID and that would then be set on the cameras.
Hopefully this gives you some Ideas.
Guest (4)
