GT
Layered GT Graphics
Hello all! I will try and keep this short. I am working with sports graphics, this time specifically is basketball. I have a graphic created for my score bug that has all the scores and team names and so forth on it. I also need separate images for each of the teams 4 time outs, and the bonus and double bonus for each team. Is there any way to have all of those elements saved into one preset and be able to trigger them on and off via shortcuts? I currently have all of my elements created as separate gtzip files and imported as inputs. I then utilize the multiview layers to toggle those elements on and off, but that leads to a larger amount of inputs in my vmix file than what is ideally desired. The way I am doing things right now works and is effective, but I would just like to clean up my presets of some excess inputs if possible.
Any thoughts or input would be greatly appreciated!
Joined: 7/17/2020(UTC) Posts: 59  Location: Makati City Thanks: 11 times Was thanked: 5 time(s) in 5 post(s)
Originally Posted by: Martin Block  I dont think that will quite work as I need everything to be visible at first and then I need to turn each element off individually as the teams use timeouts and such. Unless I can just label each element as a separate page and then turn them off and on as needed.
Joined: 6/16/2020(UTC) Posts: 77  Thanks: 8 times Was thanked: 2 time(s) in 2 post(s)
This is something similar to what I'm looking for and I don't know how to solve it, I can't hide all the layers, not even using pages ... I hope you notify when you have solved that detail, for now it only remains to use several entries translated from spanish by google https://forums.vmix.com/...e-Layers-with-Animations
GT
Layered GT Graphics
