videomusic
#1 Posted : Saturday, October 16, 2021 10:27:37 AM(UTC)
videomusic
Poland
Please, even leave a short info on whether nonGPU cards work in these cases.
I have already doing everything and tried different;
I want to make sure my Node Pro is partially damaged.
(visual mechanical and power signal is on boards TB of enclosure and testet card ok.)
Help from Akitio is negligible at the moment. Thank you all.
[Tested:
- newest laptops with TB3: upgrade/non upgrade W10, drivers, firmwares,
- drivers for testing card (i.e. BlackMagic Intensity, Avermedia, other).
- TB driver/firmware/controlcenter. DMA security on/off.
- various cables and ports TB, restarts, power up orders. ]
#2 Posted : Saturday, October 16, 2021 9:07:49 PM(UTC)
@ videomusic
Check at the bottom of this page:
https://www.vmix.com/sof...are.aspx#capturehardware
SportsNetUSA.net
#3 Posted : Monday, October 18, 2021 3:28:43 AM(UTC)
SportsNetUSA.net
Have you tested with Blackmagic or AverMedia software?
videomusic
#4 Posted : Tuesday, October 19, 2021 10:52:12 AM(UTC)
videomusic
Poland
Yes: with BlackMagic Intensity Pro driver and software, and another example Avermedia GC570D driver and software. Both latest.
#5 Posted : Wednesday, October 20, 2021 9:54:41 PM(UTC)
@ videomusic
You may need to contact Akitio support.
This compatibility chart may also be relevant:
https://www.akitio.com/i...card-compatibility-chart
SportsNetUSA.net on 10/22/2021(UTC)
