fabfab10
#1 Posted : Saturday, October 9, 2021 6:37:42 PM(UTC)
fabfab10
Italy
Does anybody know if stream deck il handled by vMix as a midi controller or in a proprietary way?
I would like to use it along with shuttle pro, which is midi, so i should need to change midi channel.
Also, midi controllers are capable of controlling vMix even when another software windows is focus, ie Universal Title Controller, keyboard of course is not.
That is useful if you are interacting in UCT (like updating a scoreboard) on the same computer and you want to switch sources or some other functions.
gorbva
#2 Posted : Monday, October 18, 2021 8:44:39 PM(UTC)
gorbva
Kazakhstan
I use Stream deck (XL an mini) to operte vMix, but with Bitfocus Companion. This allows me to control vMix and Blackmagic ATEM from one device.
#3 Posted : Monday, October 18, 2021 9:21:05 PM(UTC)
So does the streamdeck with its own software when one uses a "website" button and give it a HTTP WEB API function or by using the vMix streamdeck plugin
I don't see any reference to Midi control even in the developers section of the streamdeck
